So, I have a store bought Asus CM6830-07 Desktop Computer. It has a ASUSteK Computer Inc Motherboard, Model CM6330_CM6630_CM6730_CM6830. I have an Ivy Bridge Intel Core i7 3770 Processor. The BIOS is American Megatrends Inc Version 0507. I bought 2 sticks G.Skill F3-1600C9-8GXM Memory that, of course, is rated for 1600 Mhz but apparently only if I can enable the XMS profile, there in-lies the dilemma. I can see the XMS profile in the BIOS but there is no way that I can find to activate it or even do a manual clock and I am stuck on the JEDEC profile that is under-clocking the ram to 1333 Mhz.
So, question is, am I just stuck with under-clocked ram or is there something I am missing to get the BIOS to let me use the XMS profile? Do I need to try and download some short of update for the BIOS (although I am currently running the most current profile that is released from the manufacturer) and run the risk of bricking my entire computer with a Non-OEM BIOS, or jut live with it stuck at 1333Mhz?
Any help is greatly appreciated.
Thanks.
Thanks.
.... welcome to the wonderful world of Asus support....in all sriousness, think I'd write back and demand to be connected with a supervisor, or ask for an email address for upper management since the 'tech support' folks appear lost. I've had luck with that approach
