I'm planning to build a system based on the Gigabyte GA-Z77X-UD4H running either a Core i7-3770K or i5-3570K, and I'm hoping y'all can make some recommendations regarding memory. Specifically, I'm looking for 16 or 32GB kits, 1600 or better. I know both of those are probably overkill and 8GB should do the trick (at least that's what everyone seems to say), but I under-built my last system and regretted it ever since.
Most importantly I'm looking for a hassle-free installation and use, and that's the biggest reason I'm here. While I know that QVL's and Configurators never include every compatibility-tested kit, knowing that I'm not taking a total shot in that dark makes my hand shake a little less when I go to spend the money. And, just my luck, the UD4H isn't on G.Skill's Configurator quite yet.
So, if anyone has some experience with this board or informed suggestions as to which kits might work best, I'd greatly appreciate the advice.
