Hi
I bought a 2x4GB set F3-14900CL9D-8GBSR (1866MHz DDR3) , I intend to use them with Asus CrossHair IV Formula + AMD Phenom II X6 Black 1090T.
The timings for 1866MHz are 9-10-9-28-2N, my question is what are the timings for this memory used @1333MHz and @1600MHz?
I would expect the timings to be less for the lower frequencies but the SPD I found using google (mine hasn't arrived yet) show worse timings:
The reason for asking is that although buying a 1866 memory I intend to use it at a lower frequency and take advantage of lower timings.
Alex
Alex
