As the title says, I just bought the F3-12800CL7D-8GBXM Gskill memory and have inserted it into my newly purchased Asus P8Z77-V Pro Mobo. I also have the I5-3570k 3.4 ivy bridge CPU.
With this memory inserted I cannot get to Bios. All I get is the red blinking light on the Mobo next to the memory.
Things I have tried:
No matter what I did I could not get to Bios.
So I bought a single cheap stick of memory for ~15 dollars, and the computer boots.
So I bought 8GB of 9 case latency Corsair and the system boots.
Then I tried the Gskill memory again, and red blinking light on the Mobo.
I'm currently using the 9 case latency Corsair, but would like to use my 7 case latency Gskill.
The Gskill memory page says it is compatible with this Mobo.
Am I doing something wrong? Or am I not understanding something correctly?
- Inserting each Gskill memory stick individually into each Mobo memory slot
- Held the Mobo memory button and initiated the Mobo memory compatibility mode
- Made sure memory was firmly seated in each test
- Updated bios to the newest version, and then repeated all the above steps
