Need help on F3-2400C10Q2-64G bios setting
  • Need help on F3-2400C10Q2-64G bios setting
    CPU: I73930K C2
    MOB:RAMPAGE IV EXTREME(BIOS LATEST)
    DRAM: F3-2400C10Q2-64G
    VIDEO CARD : GEFORCE 8300GS(FOR DRAM TEST)
    POWER: CORSAIR AX1200
    VTT: 1.05(NOW USING) 1.05-1.25(HAVE TESTED)
    VCCSA:0.925(NOW USING) 0.89-1.25(HAVE TESTED)
    DRAM VOLT :1.575v(NOW USING) 1.55-1.7(HAVE TESTED)
    TIMING 1:10-12-12-31-2
    TIMING 2:7-313-19-10-28-10-6-7
    TIMING 3:
    TRRDR-TRRDD-TWWDR-TWWDD-TRWDR-TRWDD-TWRDR-TWRDD-TRWSR-TCCD
    2-4-0-0-8-12-1-1-5-0
    I had a i73960x C2 when I bought this dram, but I have found that it got errors(the mob show bug code: AF)when my computer wake up from sleeping, I try everything I know ,can not solve it .I change my cpu(get five i73930kC2s),and solve the errors I encountered when I use i7-3960x. the above-metioned bios setting(the most stable setting i have tested ) can pass 5 hours
    prime95 test ,but I can not pass memtest(got first error at about 40%).
    could you help me know the exact setting gskill test this dram? (i can provide my dram serial num if required).
    What kind of OC do you have on the CPU, think prob want 42-44, in that area? Might also be the 3930K can't handle 64GB at 2400, might just try dropping the freq to 2133 and see what happens
      cpu stocked , 2133 is stable.
      i just want to know the exact bios setting(or timing) gskill have used to test the dram.
      so i can use the setting to select a good cpu .(i have bought six i7 you know)
        It may differ a little from mobo to mobo and depending on the CPU....the BIOS takes the base info from the SPD of the sticks (done per set) and then is suppose to 'translate' that to the optimum settings for the mobo CPU that are installed
          Memory error found copying between 0xf3c13eb0, 0xb4713cd4, difference =10000000,
          Memory error found copying between 0xca876348, 0x8b3f5c98, difference =10000000,
          Memory error found copying between 0xd1d55578, 0x928d4ad0, difference =10000000
          Memory error found copying between 0xf936f0c4, 0xb9e6ef80, difference =400000,
          Memory error found copying between 0xfceb72b0, 0xbd0b6c70, difference =400000
          Memory error found copying between 0xd67f3b74, 0x969f3ab0, difference =400000
          memtest errors , dram address are different, differences are same(10000000 or 400000). any idea?
            Can try raising voltages of DRAM and MC, wouldn't take VCCSA over 1.25 though
              1. Try re-install DRAM module.
              2. Clear BIOS.
              3. Enable XMP and set VCCSA = 1.25V
