Hello, I have been fighting with my new build and I'm hoping you have help me isolate the problem.
I have a A6-3650 in a ECS A55F-M2 mainboard. It has two ram slots and I am trying to run a pair of F3-1066CL9D-4GBXL modules.
I am running a new 400w PSU, I had tried an older 430w Antec I had but I thought that its 20 pin vs 24 pin connection and age (5 years!) might have been part of the problem.
The issue is that If I have the stick installed in one order the system boots, but has occasional BSODs and is intermittent as to whether Windows recognizes 4 or 2 gb of ram (minus the 512mb for the GPU). Note that the BIOS and CPU-z always show both modules, even when windows doesn't.
If I swap the order of sticks the system won't boot windows at all. It resets shortly after the mouse arrow first appears. It also sometimes has corrupted video.
I am trying to figure out if I have a bad MB or bad ram. I ram memtest86+ on each stick individually and found no errors. But I did not have time to run each test very long.
Also with just one stick the ram has to be in the slot nearest the CPU or it won't recognize. I don't know if that is normal for this board or not.
The Bios auto setting match what is specified on the sticks. I would have tried more voltage but I can't find that option in this bios. This is my first rodeo with an APU, is it tied to the CPU voltage?
Is there anything I can try to get this to work or at least find out if it is a bad slot?
Thanks!
Thanks!
