Hi there,
I have a Problem with my Memory.
A week ago I got the first Blue Screen with the error: "PFN_List Corrupt .... 0x0000004E"
I googeld that problem an it came out it a Ram issue.
I testet my RAM with Memtest.
Findings:
1. a singel Ram bar works perfekt on every RAM slot on my Motherboard.
2. the other one works perfekt, too.
3. the both bars together don't work!
3.1 Memtest:
"Memory error detected! Copying between xxx and xxx did not result in accurate copy. MemTest has detected that your computer cannot accurately store data in RAM.
You need to fix this."
the Problem is in more than one Parameter.
My System:
Intel i7-950
Foxconn Flamingblade GTI
Nvidea Gefroce 560 TI OC
G.Skill RipJaws X 4x2 GB DDR3 Ram
I hope its possible to solve my Problems.
Findings:
3.1 Memtest:
My System:
Intel i7-950
