I'm having problem with 4 sticks 4GB G-Skill Ripjaws 1600MHz 9-9-9 1.5v http://www.newegg.com/Product/Produc...82E16820231313
The prime 95 custom test 1344k with 90% ram usage, will fail instantly once I start the test, tried to play with all the voltage but I just increased 2 notch each value, didn't try more but it still fails instantly this specific test with 0.5 Round Error. Tried with XMP profile 1.2 and manually.
If I try 1333MHz the test runs fine without errors. The same ram configuration were running perfectly on ASUS P8Z77-V at 1600MHz.
My guess the motherboard is setting a ram timing the modules doesn't like.
Timing used while testing and failing @ 1600
i7 3770k
ASRock Z77 OC Formula P1.60
G.SKILL F3-12800CL9S-4GBRL x 4
i7 3770k
