Memory recommendation for Asrock Z68
  • Memory recommendation for Asrock Z68
    My MB is Asrock Z68 Extreme4 Gen3, so I would like to know which one this kits is best for me.
    G.SKILL Ripjaws Z series, F3-149000CL9Q-16GBZL, DDR3 1866MHz, kit 4x4GB
    G.SKILL Ripjaws X series, F3-14900CL9D-8GBXL, DDR3 1866MHZ, kit 2x4GB x2
    G.SKILL Ares series, F3-2133C11Q-16GAO, DDR3 2133MHz, kit 4x4GB
    Some will depend on the CPU you are running - if it's a K model I'd go with the 2133 sticks
      I have 2500K at 4.5 Ghz.
        Yep, I'd go 2133
          Thank you.
            Let us know what you decide and how you like them
