I want to know how to keep my AMD FX 8350 to stock voltages and need to know what setting for my ram don't get what the CPU NB Voltage is +0.1 does that mean CPU NB Voltage Offset is +0.1? for i have a screenshot of my BIOS if that helps. To enable my motherboard to have better support for DDR3 1866 Mhz.
Gskill Sniper 2x4 GB DDR3 1866 Voltage for AMD FX
My motherboard is Sabertooth 990 FX Not R2. I want to have my computer running stable because I see little jerkiness in my gameplay. And I think it has to do with the computer not running correct stock voltages or the ram timings might be wrong, Im using 9-11-9-29-37 what CPU-Z has on the SPD running in 1T mode.
Keep us updated, I've got to spend some time on a system, if not back tonight, I'll prob touch base here in the AM, but then have to set up a network in a small office bldg (11 drops) so prob not back till mid PM
Quick update, I now have my system stable with timings 9-10-9-28-37 voltage 1.500 On the ram it said timings were actually 9-10-9-28 not 9-10-9-29 with those timings it made my system unstable for some reason then I checked CPU-Z to see if they were the ones listed on the sticks not in CPU-Z well the ones on the sticks were the correct numbers.
