I am hoping someone here can help steer me in the right direction with my timings. I know my mb isn't on the official qualified motherboards list for this RAM, but the Extreme 4 is, and the RAM seems to be working fine at XMP timings.
I'm just not sure which way to move my timings with regard to the tRFC and DRAM/VTT voltages.
Here is what I have so far, which is slightly modified from the XMPs, and seems to be stable. I still need to run another overnight check with Prime95.
DRAM 1.642 volts
VTT 1.168 volts
tCL 9
tRCD 11
tRP 11
tRAS 31
CR 2
tWR 16
tRFC 183
tRRD 6
tWTR 8
tRTP 8
tFAW 25
tCWL 7
The tRFC seems touchy. I was reading here that base for RFC should be around 175, but that the OP in that thread wound up with 179. Should I relax the RRD/WTR/RTP and tighten RFC? Or just keep RFC at 183 since anything below that is unstable? Or should I be pushing voltages further? I had tried DRAM 1.7 and VVT 1.2, but never found timings that were stable along with those voltages.
My i2500K is at 44x100 and offset +.005 volts, and was stable with my previous Ripjaw 8GB kit.
Thanks.
DRAM 1.642 volts
VTT 1.168 volts
tCL 9
tRCD 11
tRP 11
tRAS 31
CR 2
tWR 16
tRFC 183
tRRD 6
tWTR 8
tRTP 8
tFAW 25
tCWL 7
Thanks.
