Please help... this one is driving me crazy. I have a P8Z77-I deluxe and the F3-1600C9D-16GXM kit (3570K cpu). It fails LinX at stock speeds within the first 1-3 runs at the rated 1600.
Swapping in another vendors set of memory (same size / density, rated at 1866) and running at either 1866 or 1600, the system passes. 20+ runs every single time, tested 5 or 6 times over a couple of weeks.
Here's where it gets tough... the GSkill set DOES pass in a Maximus V Extreme, same exact settings, 20+ runs, multiple times.
I'm not sure why this is not stable in the board it was intended to go into (P8Z77-I).
Using Mem TweakIt, the settings appear exactly the same. The only slight difference is on the Timings #2 page, Round Trip Latency (A) and (B) appear flip-flopped. Same with DRAM I/O L (A) and (B). (Can post screenshots if needed.)
