Memory: F3-12800CL9D-8GBRL (Ripjaws 8GB [2x4GB])
CPU: Athlon II X2 250
Motherboard: Biostar A880G+
Ever since I installed this memory on November 27th, I have been getting blue screens and reboots (without the blue screen), usually when I start playing a game like Planetside 2.
I have tried the timing listen on the card, 9-9-9-24, but the reboots still happen without the blue screen. In addition, I tested the memory with several passes of Memtest86+, but no errors were found.
I also read the guide in the "AMD CPU + G.Skill DDR3-1600" thread. That seemed to have worked, as I was able to play Planetside 2 for several hours and the computer did not reboot or blue screen. However, this morning, the computer rebooted once again under the same settings.
I would really appreciate some help, as I have no idea if its the RAM timings or something else.
