I am replacing my 5 year old HTPC. I plan to use an ASROCK FM2A75 Pro4-M motherboard with A10-5700 APU. I have no plans to OC or use gaming. My aim is to get the best memory performance that the mobo and APU will allow. The specs say 1866Mhz at 1.5V and XMP 1.3. Does XMP 1.2 vs 1.3 make a difference ie X vs Z series? I also want to put a stick in each slot (4) and thought 16GB (4x 4GB). Having a stick in each slot means no dust is going to get into those slots and stop them working in the future, a problem I have had in the past. I know this is an overkill for an HTPC but I want this this to last 5 years like my current HTPC has. Putting a matched set of memory now should mean I won't have to do anything in the memory department again. The ASROCK supported memory list is very poorly populated for these requirements.
Any suggestions. Any advice would also be appreciated as none of this is locked in yet.
. I'm pretty comfortable working with DRAM but generally buy full sets (even if I do set them manually anyway) as with a full set you KNOW they have been tested to play together.
