I am putting together a new system to be used for video editting and gaming. I am planning on getting the ASUS x79 Sabertooth MB and want to know which is the fastest/best GSKILL memory kit to get.
I am looking at the following kits:
1. Model F3-14900CL9Q2-32GBZL
2. Model F3-17000CL11Q2-32GBZL
3. Model F3-2133C9Q-32GTX
The Trident X (#3) is the most expensive but the I would pay if it is worth the difference of about $80 in price. Also, will it work in the X79 MB?
As for the MB, any comments about the Sabertooth... I was also looking at the Asus-pro and deluxe models.. I think that the Ramgape IV is overkill but would buy it if significantly better.... I will be doing just some minimal overclocking but mostly want stability and speed at stock +10-20% OC.
Thanks for your replies
Z
Z
