RAM freeze with Extreme4-M&F3-17000cl9q-16gb
  • RAM freeze with Extreme4-M&F3-17000cl9q-16gb
    I just build a new system with the following:
    asrock x79 extreme4-m
    i7 3930k
    gsikl f3-17000cl9q-16gbzh
    ATI firepro v5800
    This wsa listed as compatible on the g.skill website.
    After building and installing Win8 I get a system freeze every 2-3 days.
    I just ran the boot up MSFT memory test utility and it froze at 21 %. To me this says it is a memory issue.
    All timing settings are the default, no overclocking.
    I would appreciate some assistance.
    Thanks,
    C. R. Booth
    Do you have the latest BIOS version? Did you enable XMP in BIOS?
    Without the proper settings, the system can be unstable.
    Let us know the result.
      xmp
      Hi - thanks for the REALLY fast response!
      the load xmp option is set to auto. Is that sufficient?
      Rocky
        more info
        memory is identified as
        Gskill 800mhz (ddr3-1600) 11-11-11-28
        XMP1.3 profile 1 1067mhz, (ddr3-2134) 9-11-10-28
          Identified as 800 where? See if the XMP option has Enable or something to that effect, if enabled it should offer the option to select a profile, select the 2133 or Profile 1 option
            Identified...
            Identified in the bios screen. As I mentioned, profile 1 is selected
              Test one module at a time to see if one may be bad causing problems.
