Hello all!
I am building an i7 3930K system for a friend of mine, for use with After Effects; the
motherboard will be an ASUS P9X79 WS.
The GSkill 32GB 2400MHz TridentX CL10 kit (code F3-2400C10Q-32GTX) is described
as being for Z77, but would two of these kits work ok on an X79 board such as the above
ASUS? Also, just out of curiosity, would this kit run at CL9 when operating at 2133MHz?
I had originally planned on getting the 32GB 2133MHz RipjawsX kit (F3-2133C9Q-32GXH),
but supplies of this are far too low for reliable purchase. Hence, I wondered if the
TridentX would be ok instead (better supply), and it would have more headroom anyway
(2133MHz is plenty; I don't expect to run higher than that with an oc'd 3930K).
Oh, just one minor concern, I notice the DIMM height of the TridentX is 54mm vs. 40mm
for the RipjawsX - could this be an issue? I intend to use is the Phanteks PH-TC14PE.
For reference, the rest of the system will be a Quadro 4000, 240GB SSD, 1000W PSU,
LSI SAS RAID, etc.
Thanks!!
Ian.
PS. My own system is a 5GHz 2700K with 16GB GSKill RipjawsX; interesting to note the
RAM was marketed as being aimed at Z77, but it works fine on my ASUS P67 (Maximus IV
Extreme). For the X79 build though, I thought it wise to ask before spending 460 UKP.
LSI SAS RAID, etc.
Thanks!!
Ian.
