DDR3-1866/timings/problems
  • DDR3-1866/timings/problems
    Hello everyone,
    I've been attempting to do this myself, but however have been having issues.
    First thing first.
    RAM: http://www.newegg.com/Product/Produc...82E16820231460
    CPU: AMD FX-8120 3.1Ghz
    RAM: 16GB DDR3
    MOBO: MSI 990XA-GD55
    So what I've been trying to do is get a stable DDR3-1600 clock, since (I think) dual 4 dimm 1866 is not possible with my board from what I heard (or is it)
    I've read the AMD sticky about setting up the frequency's because my RAM would say I only would have 12GB or 7GB or even 2GB available every once in awhile, with the timings that newegg has, I get a stable 16GB 800Mhz (if I set the profile in bios to 1600, I can't boot with it set to 1866, it just doesn't even load bios)
    However I've notice my RAM read/write has been really slow with the timings so I read somewhere that my board doesn't support stock 1866, so I'm guessing the timings I set was for 1866? so I changed it to the profile that XMP-1600 from cpu-z and finally I seemed to have a stable stock DDR3-1600..however lately I've been getting a MEMORY_MANAGEMENT BSOD so I'm guessing something is off, maybe a voltage?
    So it's as simple as this...
    If I could use 1866 on all 4 dim's what voltage, timings, and etc would I use?
    If I can't, how can I get a stable 1600 (voltage, timings, and etc)
    Thank you very much!
    The FX CPUs are rated for UP TO 1 STICK per channel at 1866 and that is with a CPU OC, some of the 8120's have problems even w/ 1 stick per channel. Think I'd try at 1600 8-9-8-28 and CR (Command Rate/Timing) at 2T or 2N. Also since it sounds like you are running two sets, which can be problematic in of itself, might want DRAM voltage at 1.6 to start and raise the CPU/NB voltage from whatever AUTO has it set on to add + 0.10
      One problem, I've been trying to find the stock CPU/NB voltage, and I can't seem to find it, from what google tells me it's v1.1 any idea?
        Normally about that, I generally start kicking it up + 0.10 and work from there, some will pop right to 1.3 or even higher to start, but I like to keep voltages as low as possible and stay stable - more voltage = more heat
          I've been getting 0x000024 BSOD lately, very rarely, I'm guessing it might be because of this, I'll add another +0.10 does that sound like it could be the problem?
            Might try it and see if it helps that BSOD normally has to do with a hard drive...might try going to Command Prompt and run a CHKDSK /F reboot and let it run through the check disk, might also go to Command Prompt and run a system file check - at command prompt SFC /SCANNOW
              Tradesman,
              I left memtest over night
              this is what I got:
                Memtest one module at a time with EOCP/DOCP, or manual settings.
                Also, make sure the memory is firmly installed, it is strange the capacity changes..
                Keep us posted.
                  Keep us posted.
                  I don't have time to do that, I work in a couple hours I'm just going to have to buy another 16G set, besides I bought 4x 1866, which is a problem of itself (being stupid) so I'll go buy 4x4GB of DDR3 1600 instead
                    It's the same thing.. you just have memory capable of a higher frequency. You can easily set the memory to DDR3-1600, which is the same as a DDR3-1600 kit.
                      GSKILL TECH,
                      I sounded a bit harsh over a half a year ago,
                      I've done some research, and I wanted to apologize for sounding like that first of all.
                      When I set the CPU-NB to 2400Mhz,
                      computer completely freaks out - I set my CPU-NB Voltage to 1.2v and attempted 1.3v but same results, I will take pics of the configuration and post it up in just a sec.
                      Here is the pic:
                        No worries! It's nothing at all, I get much, much worse all the time!
                        Based on your picture, definitely some changes need to be made.
                        CPU-NB Ratio is fine on 10 because you have the FX CPU.
                        CPU-NB Frequency 2000MHz is more than enough for DDR3-1600.
                        Same with HT Link Speed, 2000MHz is fine. (Ratio: 10)
                        CPU-NB Voltage around 1.20V is good.
                        Let me know how that works.
                        What RAM are you using? 2 or 4 modules?
                        Also, do you have the latest BIOS?
                          Do you mean, if I'm using 4 sticks? or 2? I'm using 4x8GB DDR3 1866 (I know, my mobo/CPU only supports 1 1866, I screwed up lol)
                          Thanks.
                          PS: Yes I believe I do have the latest bios, I gotta check it's been over a year)
                            Actually if you boost CPU-NB Voltage, it can support 2 1866.
                            32GB can work at DDR3-1866, just not at AUTO settings. It needs that voltage boost to be fully stable.
                              What should I boost the CPU-NB Voltage too? estimated?
