RipjawsX F3-2133C9D-16GXH (2x8Gb) installed package pair, no mixing with other modules.
Configuration 1:
m/b Gigabyte Z68MA-D2H-B3 (mATX)
Intel 2600K
Memory run at 1600 7-8-8-24 1T 1.6V
Can't overcome 1600Mhz. Tried overclocking CPU, increase QPI/VTT to 1.16V, big latencies,XMP profiles.
Configuration 2
m/b Asus P8H77M (mATX)
intel Core i5-3450
Configuration 3
m/b Asus Rampage II Gene (officially supported max 2000Mhz overclocking)
intel 920
memory run without problem using XMP profile 1 at 1866Mhz
Timings 1866:
CAS latency 8
RAS to CAS Delay 10
RAS PRE time 10
RAS ACT time 29
RAS to RAS delay 6
RFT Cycle Time 232
Write Recowery Time 14
READ to PRE time 8
Four ACT WIN time 28
Back-to Back CAS delay 0
Timing mode 2N
Round Trip Latency CHA 57
Round Trip Latency CHB 59
WRITE to READ delay DD 7
WRITE to READ delay DR 7
WRITE to READ delay SR 19
READ to WRITE delay DD 9
READ to WRITE delay DR 9
READ to WRITE delay SR 9
READ to READ delay DD 7
READ to READ delay DR 6
READ to READ delay SR 4
WRITE to WRITE delay DD 7
WRITE to WRITE delay DD 4
at 2133 abble to run Windows, but with errors
Timings 2133:
CAS latency 10
RAS to CAS Delay 15
RAS PRE time 15
RAS ACT time 31
RAS to RAS delay 7
RFT Cycle Time 298
Write Recowery Time 18
READ to PRE time 8
Four ACT WIN time 32
Timing mode 2N
Round Trip Latency CHA 68
Round Trip Latency CHB 69
WRITE to READ delay DD 5
WRITE to READ delay DR 5
WRITE to READ delay SR 21
READ to WRITE delay DD 11
READ to WRITE delay DR 11
READ to WRITE delay SR 11
Question: there is any ability to run F3-2133C9D-16GXH at 2133 on Gigabyte Z68MA-D2H-B3?
Gigabyte Z68MA-D2H-B3 avaible bios options:
CAS latency
tRCD
tRP
tRAS
tRC
tRRD
tWTR
tWR
tWTP
tWL
tRFC
tRTP
tFAW
Command rate
IO latency
Round Trip Latency
"QPI/VTT Voltage"
"DRAM Voltage" (set to 1.66)
(Question:There is any mATX motherboard that support RipjawsX F3-2133C9D-16GXH (at 2133)?)
Configuration 1:
Intel 2600K
Configuration 2
intel Core i5-3450
Configuration 3
intel 920
Timings 1866:
CAS latency 8
RAS to CAS Delay 10
RAS PRE time 10
RAS ACT time 29
RAS to RAS delay 6
RFT Cycle Time 232
READ to PRE time 8
Timing mode 2N
Timings 2133:
CAS latency 10
RAS to CAS Delay 15
RAS PRE time 15
RAS ACT time 31
RAS to RAS delay 7
RFT Cycle Time 298
READ to PRE time 8
Timing mode 2N
CAS latency
tRCD
tRP
tRAS
tRC
tRRD
tWTR
tWR
tWTP
tWL
tRFC
tRTP
tFAW
Command rate
IO latency
Round Trip Latency
"QPI/VTT Voltage"
