All good afternoon! A week ago I became the happy owner of the Asrock X79 Extreme9 motherboard and a set of memory of G.Skill TridentX DDR3-2400 16GB. The thought on compatibility has come after the order, has casually seen somewhere on the Internet. Generally configuration following: Asrock X79 Extreme9, i7 3930K C2, G.Skill TridentX DDR3-2400 16GB and Zalman CNPS12X; having collected system and having connected everything I has received the following: http://imageshack.us/f/812/33021893.png/ and http://imageshack.us/f/163/120929150318.png/ - having read various forums, I have understood that for start by default everything is normal, here so memory was defined in uefi http://imageshack.us/f/824/120929150343.png/, but it would be desirable to receive if not the maximum frequency of memory then close of those that is specified in CPU-Z or here http://imageshack.us/f/607/120929150433.png/.
My first attempts with running start to deliver to XMP 1 or XMP 2 have led to that the system has ceased to be started in general. In attempt to expose frequency of memory in manual http://imageshack.us/f/607/120929150433.png/ the same, refusal to be started. Looking through your forum I has understood later that settings exposed by default http://imageshack.us/f/521/120929150442.png/ and http://imageshack.us/f/696/120929150504.png/, and it is possible and http://imageshack.us/f/268/120929150450.png/, do not promote normal start of memory and system as a whole.
Has found instructions for Asus but that for Asrock X79 Extreme9 and similar it is rumpled; took proceeding from that that the system had some margin of safety, for the next 3-4 years.
Whether and still such question at dispersal of memory it is necessary to drive the processor or not and if yes, that as is correct, Asus Striker Extreme before used, but has come to change time a platform as has become outdated and does not pull.
If it will be not difficult to you or there is a possibility make the detailed instruction as well as that it is correct to adjust, very much I am afraid to spoil the equipment, on how many change of settings in general is safe for the motherboard and memory. It would be desirable to receive result not that that by default 1600, and at least 2000 or 2133, well as a last resort 1866.
I hope for your understanding and ingenuity, transfer machine and it is executed in the PROMT 9 program as I live in Russia and with English badly a sign. For one it will be possible will check compatibility of this set of memory with X79.
If you will not complicate explain as correctly to include a XMP profile in Bios that everything worked. That the system would start and was stable. And if that is possible with screenshots, for descriptive reasons.
