Quick question here. Can you forsee any problems with a set of Sniper Series F3-14900CL9D-8GBSR with a ASUS Crosshair V Formula AM3+ AMD 990FX and a X4 960t? I did do some research on my own and everything points to no problems....just need an expert second opinion. Thanks
Compatible?
I can manage 1600 on my 965BE + M4A89GTD Pro USB3, but 1866 may be a stretch. Worst case senario you run the ram at 1600 (or 1333) until you get the 8150AMD Phenom II x4 965 BE
Noctua NH-U9B SE2
Asus M4A89GTD Pro USB3
G. Skill Ares 16GB F3-1866C10D-16GAB @1600 9-9-9-24
Samsung 830 Series 256GB SSD
XFX Radeon HD 5850 Black Edition
Corsair HX850
Antec 900
Winidows 7 -64bit
native at 1600
sorry it has taken me so long to get back to you..I installed the F3-14900CL9D-8GBSR in my crosshair v formula and it runs native at 1600! I have bumped that up to 1760 with no problems! Cant wait til I upgrade my cpu to really oc these sticks! Thanks again for all the help! Until next time..take care
Great to hear that you have had some good success with that RAM.....can't wait to hear about the 8150 when that goes into your rig.AMD Phenom II x4 965 BE
Noctua NH-U9B SE2
Corsair HX850
Antec 900
Winidows 7 -64bit
