DDR3-2400 16GB Quad Channel [RipjawsZ] not working 2400
  • DDR3-2400 16GB Quad Channel [RipjawsZ] not working 2400
    I have recently purchased DDR3-2400 16GB Quad Channel [RipjawsZ] F3-19200CL11Q-16GBZHD memory
    The memory does not work at 2400 frequency - the system wont boot. I had to reset the MB and choose manually the memory's frequency to 2133 Mhz and the the system starts ok.
    My hardware
    ASRock X79-Extreme 9 M/B, Socket 2011, Intel X79, 8x DDR3, 7.1ch Core3D Audio, GbLAN, 5x PCI-E 3.0, SATA3, RAID, USB3.0, Quad SLI/CrossFireX, ATX GTX680, 2GB, DDR5, 256bit, DVI, DP, HDMI, SLI, PCIe3.0, All Solid Cap
    CORE I7 3960X Intel CORE i7 3960X/ 3.30GHx/ 15MB CACHE/ LGA2011/ 6CORES + INTEL THERMAL SOLUTION A
    Seasonic X-Series 1250W Power Supply SS-1250XM
    Do you have the latest BIOS? If not, try updating, if so try at 2133 jsut to test and see if sticks run okay there
