Having a hard time finding a solution for the issue I am having. New Build - Asus P9X79 board (with latest BIOS just installed) and F3-12800CL10Q2-64GBZL kit of Ram. Only sees 48 GB of RAM. On the MB I get an error on Slot C1 and C2 about them being ?Abnormal?. I moved the RAM around to try different RAM in the C slots and get the same result. I tried using XMP and I still get the same 48 Gb of RAM showing up. I am pretty sure everything is working and I just need to manually set timings?.but I am unable to find any that work.
Can you please provide info on what I need to do??
Much appreciated.
Dan
Much appreciated.
Dan
