Hi and hello! My rig consists of the following components:
Mobo: GA-970A-UD3
CPU: AMD Phenom II X4 965 BE
GPU: Nvidia GTX 560 SC
PSU: Corsair Builder Series CX500
RAM: F3-14900CL9D-8GBSR
I would appreciate some help for my understanding of what I need to do .
As I've read, I'll have to use my RAM at 1600 (which is not a problem at all). However, the problem is the manual settings that I have to do. Thoroughly searching through the forums, I hadn't been able to find any threads that involved an AMD CPU that wasn't FX and the ram was 1866.
And so, I'd appreciate some help with the configurations I'll have to do for my RAM in BIOS so my computer's stable. Thanks ahead of time .
Mobo: GA-970A-UD3
