hi
well i decided to go with asus p8z77-v and F3-2400c10D-8GTX (2kits) ddr3-2400 cl10-12-12-31 1.65v pc3-19200 4gx2 ram
so after bulding up the system i was getting problem while overclocking in auto tune mode with asus ii suite
problem is :
well when i try to auto tune the system won't boot up so i tried 2 dimm sperately and system booted up and in auto tune the first 2 ram over clock higher cpu ghz than the second 2 ram
for example: ram kit 1 over clock on auto tune to 44 or 45 ghz in auto tune mode
ram kit 2 over clock cpu to 41 on auto tune
system :
i7 3770k
p8z77-v
4*4g gskill trident x
corsair h80
sesonic 750 watt
gtx 750 sli
if i tried the four dimm the system won;t boot up
i bought the 2 kits sperately but they both have the same model and even in serial they are like 1-2 / 4-5
btw: the four stick run on xmp porfile just fine on 2400
problem is :
system :
i7 3770k
p8z77-v
corsair h80
sesonic 750 watt
gtx 750 sli
