IMPORTANT: I have a Noctua NH D14 cpu cooler: Memory must be 40 mm tall maximum Trident @ 54mm is too tall
I have read many posts on this MB CPU combo but I remain confused. I hope someone can help.
1) Whatever speed memory I buy for this combination I would like the speed to be recognized by the ASUS P8Z77-V Pro without manual settings, if possible. Simple plug & play. I am running the latest bios (July?).
2)I had intended to buy a 4x4 set for 16 gb but see conflicting advice...2 8gb leaving two slots open conflicted by concerns about finding a matching pair later.
3) I am a novice at overclocking but I do want to experiment. I will start out using the MB overclocking features.
4) I have a budget of $100 +/- to a $125 maximum.
5) I prefer to shop at Newegg.
Can someone make suggestions for this combo with the above constraints and advise on the 2 stick versus 4 stick conundrum.
Thank you.
Thank you.
