Hi guys!
I am trying to find a way to increase my RAM in my work computer, as it has only 2x2GB of DDR3.
This computer is a Lenovo M58P 6137-CE2.
Officially, it is supposed to support only up to 8GB of ram, as it has a Q45 chipset and it seems to be a limitation of it.
However, one of its bios update enabled 4GB dimm support :
5CKT67A/5CJT67A
- Support 4GB DIMMs.
(bios changelog is here)
Therefore my question is quite simple, what ddr3 kit should i put inside this little guy?
It has two empty slots, the easy way would be to just take 2 more sticks each of 2GB and let it stat at 8gb.
But the fact it is supposed to support 4GB dimms make me want to try to feed him with 2 sticks of 4GB, putting it at 12GB. I fear it *could* boot with 2 dimms of 4gb each, but not more (not 2x2gb + 2x4gb).
I NEED more ram, but can't change the machine just yet.
I even thought of buying a F3-2133C11Q-16GAO kit, if it works with the Lenovo then fine, if not then it goes inside my home desktop to expand my current kit (F3-17000CL11Q-16GBXL, running with a MSI X79A-GD65 8d).
What to you guys think?
Did i already answered my own question?
5CKT67A/5CJT67A
