Specs
Intel i5 3570k at stock speed
Asus P8Z77-v pro with 1206 bios
Gskill F3-14900CL8D-8GBXM
Corsair AX850 Power supply
Asus gtx 670 with dcuII cooler
Plextor M3 pro 256gb ssd
Hello all. I've been over this with one of your techs on the phone but thought I should get some more opinions before I spend more money on shipping and you spend more money on replacing my ram. The first set I bought from newegg was never stable at it's rated speed of 8-9-9-24 1866mhz @1.5v per xmp profile as far as I could tell. I got a replacement from the egg and ran memtest86 the next day all day while I was at work for a total of 13 hours with no errors. I also ran prime 95 in blend mode for a couple hours for good measure, also without errors. Not long after I got crashes in some games and weird behavior in win 7. I warrantied or replaced my psu, motherboard, and boot ssd. I thought I had figured it out as being a sound card driver issue when switching back to onboard audio let me game for about 5 hours without crashing. Unfortunately this was a fluke and I had a freeze or 2 soon after which led me to double check my ram after a round of banging my head on the wall. I got errors in prime 95 blend almost immediately at the same settings that had passed testing with flying colors immediately after I bought the ram. However, it seems to be stable at default safe settings of 11-11-11-28 (I think). Am I really that unlucky or is there some kind of incompatibility I'm unaware of? I looked up this model of memory on the gskill site and it says it works with my motherboard. Is this just going to keep happening if I keep sending the set back for warranty? Please help. For the record yes I use a grounding strap and touch my case too.
