eVGA 780i and PC8500
  • eVGA 780i and PC8500
    I just replaced my Intel E6700 with a QX9650. After installing the CPU clearing the CMOS I now get this "Warning! Now System is in Safe Mode. Please reset CPU or Memory Frequency in the CMOS setup" If I un link the ram to get it to run then It will only run @ 400. If I remove 2 sticks = 4gb then it will run at 800. Any ideas on how to fix this? I would like to run all 8gb if I can.
    Motherboard eVGA 780i SLI
    G. SKILL DDR2 PC8500 F2-8500CL5D-4GBPK CL5-5-5-15 total of 8GB @ 2.1V
    CPU QX9650 on water idle @32c and 39c while gaming
    Video card eVGA GTX580 Classified 3gb
    Sound Blaster Titanium Fatal1ty Pro series sound card
    PC Power and Cooling 750W Silencer Quad SLI PSU
    Thermaltake Armor class full tower
    Hitachi 500gb HD 7200
    OCZ SATA III ssd 120gb
    Windows 7 64bit Pro
    May want to reset the CMOS, there's a jumper pin on the motherboard or can remove the CMOS battery (instructions for both should be in your manual
      Thanks for your input but I have done that already.
        Can you post your BIOS settings, voltage may be low somewhere on initial boot
          I don't know how?
            Uploaded with ImageShack.us
              No one has any ideas?
                Might try raising the MCP voltage .05 to 1.55
                  Where does it say MCP .05?
                    Looks like he's saying raise the MCP voltage from 1.5 to 1.55, it's on the 3rd screen you posted , the nForce MCP setting
                      Do you have the latest BIOS? tWR should be 8
