MSI P35 Platinum:
Crucial 1066:
CPU ?:
What is the difference between the NT, NQ and PQ versions of the F2-6400CL5D DDR2 800 ram? Just adding some ram (going all new) to this vanilla (no OC) system. I know the NT doesn't have a heat spreader. Anything else?
System is running XP 32 bit. Don't know if I should get 4 gigs of NT, NQ or PQ??? I'm staying away from the 1066 high voltage ram. I know 1 gig will be wasted on the 32 bit system.
Crucial 1066:
CPU ?:
