Hi, I have just recently purchased 2 of the F2-8500CL5D-4GBPK kits from a company in England.
I have read through various listings on this forum in terms of getting them stable.
I made sure to check the QVL of the asus board and this memory was listed and this was my reason for buying it.
I am aware that it states that 1066Mhz be only be supported on 2 DIMMS and that I should consult the QVL, well the QVL states that this memory will run 4 DIMMS as it has a little dot in the A, B, C section on there stating as such.
Also from what i have gathered the 1066 issue was with earlier processors and earlier BIOS and that it had been rectified with better IMC from AMD.
I am running an AMD 1090t X6 3.2Ghz processor on the 2403 bios which is the last available for the board, it states at ASUS that this processor was compatible from BIOS 2201.
I fully expected given all this that when i set the BIOS to 2.1V and the DRAM frequency to 1066 that I would be able to boot without issue.
Of course this wasnt the case at all.
I have tried the chips at 800Mhz, even at 4-4-4-12 and all seems well but 1066 is a no go.
I have tried lowering the TRFC to 195ns, CPU-NB voltage to 1.4v, HT voltage to 1.3v, NB voltage to 1.4v all with a TRC setting of 41 which is the highest my board will allow, all to no avail, the dimms will not remain stable, I have managed to boot into windows with these settings but it crashes within seconds of logging in, have also tried raising the CPU-NB frequency.
By overclocking the bus frequency to 250Mhz I seemingly can gain stability at 1000Mhz on the RAM with all settings on auto, which boots up at 5-5-5-15-24 this is using the 800Mhz divider in my BIOS. But this not really ideal, Having read on here that 800Mhz at 4-4-4-12 is faster than 1066, I can categorically state that is not, the bandwidth at 800Mhz with 4-4-4-12 is 7.41Gb at 1000Mhz at 5-5-5-15, it is 9.41Gb that is a big difference in bandwidth and the latency was increased from 57ns at 1000, to 63.6ns at 800 with the tighter timings.
System as follows:
AMD 1090T X6 3.2Ghz processor
M4N72-E ASUS motherboard with NVIDIA 750a chipset
GTX 470 SOC graphics card.
500Gb boot drive.
This is a ridiculous situation that either ASUS or GSKILL need to sort out.
I have previously had OCZ reapers running in this board at 8GB at 1072Mhz but when i got a bigger CPU cooler, I needed lower profile memory, I thought that I had found some that fitted the bill.
I have also installed a 120MM high rpm fan blowing directly over the DIMMS.
System as follows:
500Gb boot drive.
