F2-8500CL5S-2GBPK and p5n-e sli
  • F2-8500CL5S-2GBPK and p5n-e sli
    Model of the motherboard: ASUS p5n-e sli
    Model of the memory:F2-8500L5S-2GIGBPK
    Model of the CPU: E6300
    What is the problem? booted at first cpuz recinized all 4 gig then it would blue screen memory error and physical memory dump would run.
    I adjusted the memory settings in the bios to what I thought was for this combo. Now it wont boot at all. I am going to reset the cmos tonight and get everything back to default. I just need to know what would be the correct memory settings for this board and memory. I tried searching but havent found anything yet.
    pheonixbios ver. 0307 has not been fashed or updated.
    thanks for any help and sorry for the crappy grammer and punctuation.
    Update to latest BIOS first, then load BIOS defaults, then manually input memory settings.
    DDR2-1066
    5-5-5-15
    2.10V
    Or you can try
    DDR2-800
    4-4-4-12
    2.0V
      Thank you very much. system is stable now. I think the bios was the main culprit. Can you give me any guidence on getting my memory to run at 1066 its showing 400 in cpuz. If I turn up setting with gen clock it locks up at 2.4Ghz for the cpu and thats were I need to be to have the memory at 533. I would prefer to do this in the bios if you can help.
      Thanks in advance
        Where does it show 400? What is shown in the memory tab?
          400 mhz 2.3 ratio
            400 will mean it's running at 800 (400 x2 as it's DOUBLE Data Rate) if it locks up at 2.4 for 533, you probably need more vCore voltage and/or NB voltage, can you post your BIOS settings (and do you have the latest BIOS)
              thanks will try that next
                Let us know how it goes
                  I can unlink the cpu and ram in the bios and 2.4 cpu is very stable. But I cant bring my memory speed up to 1066 do I need to change the NB voltage to do this and be stable.
                    CAN try raising it a little, what's your FSB at?
                      from CPU-Z
                      Processor 1 ID = 0
                      Number of cores 2 (max 2)
                      Number of threads 2 (max 2)
                      Name Intel Core 2 Duo E6300
                      Codename Conroe
                      Specification Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
                      Package (platform ID) Socket 775 LGA (0x0)
                      CPUID 6.F.2
                      Extended CPUID 6.F
                      Core Stepping L2
                      Technology 65 nm
                      Core Speed 2333.2 MHz
                      Multiplier x FSB 7.0 x 333.3 MHz
                      Rated Bus speed 1333.3 MHz
                      Stock frequency 1866 MHz
                      Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
                      L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
                      L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
                      L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
                      FID/VID Control yes
                      FID range 6.0x - 7.0x
                      Max VID 1.325 V
