from ''Edited". No, I don't think so
The board automates the NB/HT. That might be too high. RAM you could get stable with simply voltage.
however, here's one comment of fellow from extremeclockers with same board as yours:
As you can see it is very low, but your 2.3v on it should in that scale just and just do the 2.15v on RAM, but I still suspect this to be too high voltages on NB/HT and drop of 5 V rail on PSU. Drop the NB to near 1.40v and HT to 1.26v. vCore is only stable up to 3,5Ghz at 1.40v depending. According to this source the NB/HT needs incredible low voltages. Here's couple screenshots of stable 3,679Ghz and 4,0Ghz:
http://forums.extremeoverclocking.co...1&d=1246930628
http://forums.extremeoverclocking.co...2&d=1246930628
http://forums.extremeoverclocking.co...3&d=1246930628
http://forums.extremeoverclocking.co...4&d=1246930628
http://forums.extremeoverclocking.co...5&d=1246930628
http://forums.extremeoverclocking.co...6&d=1246930948
(Although, I know G.Skill memory takes like insane volts at least what I am using on 1066Mhz yet I doubt it needs more than actual 2.24v.)
I have a wierd problem. For some reason MY Gigabyte GA-MA790X-UD4P motherboard with a OCZ Low Voltage 1066 4GB kit installed will give 2.05v to ram when "normal" is selected for ddr2 1.8 voltage (as listed in bios) If I increase the voltage by +.1 volts, the motherboard instead of giving true voltage of 2.15, applies less voltage of 1.95. From there the scaling is correct, as each +.1 increment is applied, voltage increases appropriately. However this motherboard should allow 1.8 volts (or 1.85 if slightly overvolted), but the least applied to ram is 1.95. I ended up Returning this ram after trying various bios without successfully being able to apply 1.8volts or close.
