Well, that anyway didn't go too good. Need to think a bit, if -1 CL gain was less than 100MB/s that means something there is now holding this thing back.
Edit #01:
I honestly am afraid that the problem is now the Memory controller speeds or FSB. Since on 1066Mhz your L3 Cache speeds just raised 1000MB/s on read speeds. CL6-6-5-18 did a lot better than CL5.
Edit #02:
Lets try something literally weird.. Try adding this there: CL5-7-7-24, tRC 25T and put tWR to 5 1066Mhz. Also, check your HTT / MCH volts wanna know what those are.
Edit #01:
Edit #02:
