F2-8500CL5D w/ DFI LP JR P45-T2RS
  • F2-8500CL5D w/ DFI LP JR P45-T2RS
    ok i have 4 sticks of F2-8500CL5D that want to run at 1066 on my lan party jr p45 board from dfi (this ram is specifically recommended for this board on the dfi website) . The problem is, it doesnt... it runs at 800. i'm running an e8400 core 2
    ive gone through the bios and set the timing, but im not sure if im doing it right (set the timing and the voltage and set it to read at 1066).
    i'd like to just have a set of instructiions to get this running right.
    To set your timings for the RAM, which is listed as compatible as you said, you need to get to the advanced area of the DFI BIOS, directions on how to enter the setup for RAM is in your manual starting around page 86, you can download the manual in PDF format here:
    http://img.lanparty.tw/Upload/Manual/CM/JRP45T2RSe1.pdf
      i had to download the pdf, cuz i just looked at page 86 on my dfi manual, and it's the dutch section.
      ok i've been through this, and ive set up the options that i knew, i'd either get failed startups... or it remaining at 800mhz
      there has to be an option im overlooking,
      does anyone have a specific walk thru of how they got their ram to work on this or a similar dfi board?
          You show F2-8500CL5D, this comes in different flavors (i.e. 2x1GB, 2x2GB) I believe most call for 2.0 to 2.1 volts, looks like yours is about 1.9.
          Also Might try ch1ch2 commonclock setting from auto to aggressive (I believe, that's how they term it)
            these arnt screenshots of my bios... these are just standard pictures from the manual (to give u guys an idea of what im lookin at easier)
            ive changed my timing to 5-5-5-15
            dram voltage to 2.1
            and set the target dram speed to 333/1066
            cpu z is showing (as is my bootup screen) 800mhz speed (398x2 in cpu z which is about 800)
              ive tried changing the voltage and timings, but cpuz and memset show its not changing
                please install only two sticks (one pair) and try again
                thanks
                G.S
                  still running at 800mhz
                    which bios version you are using?
                    Would you like to update to the latest bios?
                    thanks
                    G.S
                      i'm using latest bios, dated 2008-12-29 version J245DC29
                      also, ive noticed...even when i change my ram voltage, memset and cpuz show its not changing
                        double post. sorry.
                          we don't think memset or cpu-z would show memory voltage
                          you could use everest or dfi smart guardian to check with memory voltage
                          and please try to increase CPU VTT voltage to 1.4v
                          thanks
                          G.S
                            increased; no change
                            (everything in bios is set is on default and auto)do u want me to set the timings against or just leave it on auto
                              if you set all settings to auto, it will only run at DDR2 800 5-5-5-15@1.8-1.9v
                              so, please set them manually to DDR2 1066 5-5-5-15@2.1v, CPU VTT voltage to 1.4v
                              thanks
                              G.S
