Hi
I have an older system running F2-8500CL5D-4GBPK on Asus P5Q Turbo with E7500 * 3.66Ghz (333Mhz FSB). The system is rock stable both Prime95 and memtest86 can run forever w/o any errors. I recently decided to install Win7 64bit and got a second pair of F2-8500CL5D-4GBPK so now I have a total of 8GB DDR2 dual channel. Windows 7 64bit works ok, but I noticed that prime95 test fails after 20minutes. I ran memtest86 (using bootable cd) and it showed errors after completing 20% of the tests. I tried only the new 4GB pair alone and they seem to work rock solid just like the older couple on either slot pair
Then I tried raising both the FSB-Termination voltage to 1.4V and the NB voltage to 1.44V. Now Prime95 can be run for about 6 hours until error occurs and memtst86 was able to complete 2 passes of full tests and failed on 40% of the third test. Can I rais the NB and or the FSB-VTT more to arround 1.5V (Above 1.6V bios warns about better coolong solution for NorthBridge). Is there anything else I can try? Here are my settings:
AI Overclock Tuner - Manual
CPU Ratio Setting - 11
FSB Frequency - 333
PCIE Frequency - 100
FSB Strap to North Bridge - 333
DRAM Frequency - DDR2-1066
tCL - 5 DRAM Clocks
tRCD - 5 DRAM Clocks
tRP - 5 DRAM Clocks
tRAS - 15 DRAM Clocks
tRRD - Auto
tRFC - 85 DRAM Clocks
tWR - Auto
tRTP - Auto
tRTW - Auto
tWTR_S - Auto
tWRT_D - Auto
tRTR_S - Auto
tRTR_D - Auto
tWTW_S - Auto
tWTW_D - Auto
tWTPD - Auto
tRTPD - Auto
tPTPD - Auto
tAPTAD - Auto
tAPTRD - Auto
DRAM Static Read Control - Auto
DRAM Read Training - Auto
MEM OC Charger - Enabled
AI Clock Twister - Auto
AI Transaction Booster - Auto
CPU Voltage - 1.55V
CPU GTL Reference - Auto
CPU PLL Voltage - 1.7V
FSB Termination Voltage - 1.4V
DRAM Voltage - 2.20
NB Voltage - 1.44
SB Voltage - 1.3V
PCIE Sata Voltage - 1.55V
Load-Line Calibration - Disabled
CPU Spread Spectrum - Disabled
PCIE Spread Spectrum - Disabled
CPU Clock Skew - Auto
CPU Margin Enhancement - Optimized
FSB Frequency - 333
tCL - 5 DRAM Clocks
tRP - 5 DRAM Clocks
tRRD - Auto
tWR - Auto
tRTP - Auto
tRTW - Auto
tWTR_S - Auto
tWRT_D - Auto
tRTR_S - Auto
tRTR_D - Auto
tWTW_S - Auto
tWTW_D - Auto
tWTPD - Auto
tRTPD - Auto
tPTPD - Auto
tAPTAD - Auto
tAPTRD - Auto
CPU Voltage - 1.55V
DRAM Voltage - 2.20
NB Voltage - 1.44
SB Voltage - 1.3V
