I can not get it to run at 1066. I'm running a Phenom 2 940 on a DFI LanParty DK 790GX-M2RS motherboard. The memory is listed by DFI as useable with 4 sticks. I have tried manually setting the timings in bios and I get errors in memtest.
CPUz says the following for 1066 :
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 15
tRC 48
Command Rate 2T
Voltage 2.100 V
It does run at 800 with all settings on auto
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 15
tRC 48
Command Rate 2T
Voltage 2.100 V
