My PC configuration is the next: E6850, MSI NEO3 FR ( last bios disponible ), 4GBPQ DDR2-1000, 2xSEAGATE RAID0, 8800GT, 620 ENERMAX LIBERTY.
Running memory is possible but only at 800mhz ( 333*9 cpu ) and 2,1voltage. If i put the original 1000mhz the system became unstable. I have tested those things with PRIME95, at 800mhz works fine but at 1000 i have freezing,blue screen or booting failure. The strange thing is that a previous ram modules ,from OCZ, was 1066mhz and they work fine!! ( without setting voltage or cas latency ).
If i select "optimized..." in bios the system recognize the memory like the JEDEC specific and it's normal.It is so discouraging running these to 800mhz. I tryed all things are possible: setting the cas latency to 5-5-5-15 or low ( 4-4-4-12 with these one the system won't start) .
ps. I have tested the memory module there are not errors.
