hi gskill team,
i want to overclock my system and i thought i have good hardware.
but i cant get my system stable even with 440FSB and 9.5 Multi.
Now i wanted to try to run the RAMs at 1000 with 500FSB.
But i always get a BSOD while booting windows7 x64 and i cant pass Memtest86+ 4.11 Test 7. I tried everything. I'm even on Slot 2&4 now.
Do i have bad RAMs that need RMA?
This template is for testing 500FSB.
CPU = E8500 E0
Motherboard = EP45-UD3R
BIOS Version = F12
Ram = 2x 2GB G.Skill F2-8000CL5D-4GBPQ
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .............: Auto
CPU Clock Ratio .....................: 6
Fine CPU Clock Ratio.................: 0
CPU Frequency .......................: 3.00 Ghz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...............: Enabled
CPU Host Frequency (Mhz) ............: 500
PCI Express Frequency (Mhz) .........: 100
DRAM Performance Control
Performance Enhance..................: Standard
Extreme Memory Profile (X.M.P.)......: Disabled
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ............: 2.00B
Memory Frequency (Mhz) ..............: 1000
DRAM Timing Selectable ..............: Manual
Standard Timing Control
CAS Latency Time.....................: 5
tRCD ................................: 5
tRP..................................: 5
tRAS.................................: 15
Advanced Timing Control
tRRD.................................: Auto
tWTR.................................: Auto
tWR..................................: Auto
tRFC.................................: Auto (tried 48,64,68,80)
tRTP.................................: Auto
Command Rate (CMD) ..................: Auto
Channel A
Static tRead Value...................: Auto (tried 10,11,12)
Channel B
Motherboard Voltage Control
CPU
Load Line Calibration (LLC) .........: Disabled
CPU Vcore............................: 1.41875
CPU Termination.....1.200V*..........: 1.200
CPU PLL.............1.500V*..........: 1.500
CPU Referen.........0.760V*..........: 0.760
MCH/ICH
MCH Core............1.100V...........: 1.240
MCH Reference.......0.760V...........: 0.760
MCH/DRAM Ref........0.900V...........: 1.050
ICH I/O.............1.500V...........: 1.500
ICH Core............1.100V...........: 1.100
DRAM
DRAM Voltage .........1.800V.........: 2.100
DRAM Termination .....0.900V.........: 1.050
Channel A Reference ..0.900V.........: 1.050
Channel B Reference ..0.900V.........: 1.050
CPU = E8500 E0
BIOS Version = F12
Clock Chip Control
Channel A
Channel B
CPU
MCH/ICH
DRAM
