I bought F2-8500CL5D-4GBPK, my computer and various utilities see it as 800mhz rather then 1066mhz.
I can run it at 1066mhz but have to change the bios setting to do so, "Auto" sets it as 800mhz. Have to set the timings to 5-5-6-15 to run in dual channel rather then 5-5-5-15 as stated on the box.
IIRC I used Crucial's memory scanner to choose the memory to buy? looks like that was probably a mistake? Being as it can't properly detect the motherboard model.
"F2-8500CL5D-4GBPK" Intel memory? What if any real difference will that make? Performance suffer because of it being made for intel systems?
Motherboard - MSI K9N SLI platinum 7374
CPU - Phenom 9500
CPU - Phenom 9500
