This memory is a 2x4gb kit (so 8gb total). The motherboard (MB) will POST only if I have 1 of these sticks plugged into DIMM1 (there are two slots on the MB). I've tested with each stick independently (so each one plugged into DIMM1) and memtest seems to run ok. When I plug both sticks in at the same time (DIMM1, DIMM2) the MB will not POST. I tried plugging in each stick, one at a time, into DIMM2 and the MB will not POST. So, only when 1 stick is plugged into DIMM1 will things work.
With both sticks plugged in, I've tried increasing the CPU voltage (up to 1.4v) as well as the DIMM voltage (just over 2.0v). I've lowered the clock speed (800 --> 677 --> 533 --> 400), and tried adjusting the timings to the most tolerant (slowest) settings. Still does not work.
In all cases that the MB fails to POST, I observe the following: 3 long beeps, followed by a period of silence wherein the HDD light blinks (quick, quick, pause, quick). The beep/flash cycle repeats endlessly.
This is the second set of gskill ram I've tried with this board. The first two sticks I tried were also 4gb each, but they were not bundled as a kit (otherwise, they were supposed to have the same timings as the kit version I describe above). They also worked independently in DIMM1, but had the same problem when boh were plugged in at the same time.
Specifications follow:
motherboard specification:
GA-M68M-S2P, rev 2.3, bios FC
cpu specification:
AMD X2 5600+ (2900MHz)
memory:
f2-6400cl6d-8gbmq
other components:
Rosewill rc-211 (sata ii 2port) pcie adapter (latest IDE bios)
4x2.5 samsung spinpoint 600gb
1xAsus DVD writer (SATA)
1xOCZ-Agility (2.5 flash SATA drive)
ARK (KY-ATX450) 450W power supply
Please assist.
-James
cpu specification:
memory:
f2-6400cl6d-8gbmq
other components:
Please assist.
-James
