I'm looking to increase the memory on my Dimension 5100. I'm not tech savvy, so I'm looking for something that will work without any glitches. I can swap out the memory sticks, but that's about it.
Memory for Dell Dimension 5100
This is what I'd use;
http://www.newegg.com/Product/Produc...82E16820231135MSI Big Bang xPower x58
Intel i7 950
GSkill DDR3 2000 6x2Gb
Gigabyte GTX 460 x2 SLi
OCZ Vertex 2 SSD - OS Drive
Corsair TX950W
Yep,
I'm looking at page 99 of your owners manual right now
Four dimm slots each capable of supporting up to 1Gb of memory operating at DDR3 533
for a total of 4Gb system RAM
Based on that here you go;
http://www.newegg.com/Product/Produc...82E16820231118
Buy two kits for a total of 1Gbx4
Regards,MSI Big Bang xPower x58
Intel i7 950
Corsair TX950W
Ok, I gotcha. I thought that you had a laptop...............
Guess that I should have asked.
If it were me and I could only swing 2Gb then I would use the new kit and not mix and match.
However, you're biggest improvement will come from an upgrade to 4Gb so if you can swing that it would be best.
Here's my finaland hopefully correct recommendation
- either of these x2 for a total of 4Gb
http://www.newegg.com/Product/Produc...2%20x%201GB%29MSI Big Bang xPower x58
Intel i7 950
Corsair TX950W
