MB Gibabyte GA-MA785GM-US2H
CPU AMD Phenom X4 9750
Memory F2-6400CL5D-2GBNQ
OS XP pro SP3
Problem is blue screen crash occasionally with xp and I tried to run Windows 7 upgrade advisor and it would crash. After lots of reading I tested the memory and found one crashes running memtest86+. For now I?ll run with just the one until I can get a replacement for the other.
My Test:
I have two F2-6400CL5D-2GBNQ. I ran memtest86+ on both of them twice in slot 1. The one shows errors within seconds on both tests and the other ran about 5 min and then over an hour with no errors.
Another question
Should one F2-6400CL5D-2GBNQ show up as 1GB or 2GB?
The label on both show F2-6400CL5D-2GBNQ but CPU-Z says both are F2-6400CL5D-1GBNQ and 1024 Mbytes. On boot up I see less than 1GB ram with only one installed. Windows 7 upgrade advisor says I have 768MB of RAM and at least 1G is needed
Last question
I?m looking to up my ram and looking at F2-6400CL5D-4GBPQ and F2-6400CL5D-4GBNT. The Spec?s look the same but the one is cheaper.
Will either or both of these be compatible with the F2-6400CL5D-2GBNQ and how much ram will I have after installing the two 4GB and the two 2GB ? My thoughts are to install the 4GB so I can upgrade to win7 and then install the 2GB when I get two good ones.
OS XP pro SP3
My Test:
Another question
Last question
