Hey,
I've been trying to overclock my processor from 3.0GHz to 3.5GHz. That would require me to increase the FSB from 240MHz to 280MHz (with a 12.5x multiplier). My motherboard Asus P5QPL-VM EPU has only two memory dividers and therefore setting the FSB to 280MHz would allow me to set the memory clock to either 933MHz or 1120MHz. At 240MHz FSB it would allow me to set the memory to a minimum of 800MHz, which I've been using since it seems to be the only clockspeed that works. My memory should be capable of running at 1066MHz so I set it to 933MHz and tried booting. I got past POST but always got BSOD at Windows login.
I tried several different options. I increased the memory voltage to 2.1V and set NB voltage to the max which was 1.275V. I increased the CPU voltage by 100mV too just in case. I also set the FSB back to 240MHz and tried setting the DRAM freq to 960MHz. None of these settings worked and I just got BSOD. I also tried running memtest86 but it always froze at some point.
I then updated my BIOS to the latest one and tried out some memory timings. I tried settings like 6-6-6-18, 7-7-7-21 and some other various combinations. It booted when CL was below 7 but when CL was 7 or above it froze at POST.
At the moment I'm running at 240MHz FSB, 800MHz DRAM with 4-4-4-12 timings. But I really want to overclock my CPU more. So why can't I run my memory over 800MHz?
My bios options are the following:
AI Overclocking: Manual / Auto / Profile
CPU Frequency: 200-800
CPU Multiplier: 6 - 12.5
DRAM Frequency: 800MHz / 960MHz (increases if CPU Freq is increased)
PCI Express Frequency: Auto / 70-200
Memory Voltage: 1.5-2.5V
NB Voltage: 1.125 / 1.175 / 1.225 / 1.275
SV 1.5 Voltage: 1.5V / 1.6V
CPU VTT: 1.2V / 1.3V
CPU Over Voltage: Auto / +50mV / +100mV / +150mV
Auto PSI: Enabled / Disabled
Memory Remap Feature: Enabled / Disabled
Configure DRAM Timing by SPD: Enabled / Disabled
DRAM tCL (5)
DRAM tRAS (15)
DRAM tRP (5)
DRAM tRCD (5)
DRAM tWR (6)
DRAM tRFC (52)
DRAM tWTR (3)
DRAM tRRD (3)
DRAM tRTP (3)
DRAM tRD (4)
Specs
CPU: Intel E5200 2,5GHz
MoBo: Asus P5QPL-VM EPU (bios 0502)
BIOS: American Megatrends v.02.61
Memory: G.Skill F2-8500CL5D-4GBPK
OS: Windows 7 x64 build 7600
Thank you in advance.
DRAM tCL (5)
DRAM tRAS (15)
DRAM tRP (5)
DRAM tRCD (5)
DRAM tWR (6)
DRAM tRFC (52)
DRAM tWTR (3)
DRAM tRRD (3)
DRAM tRTP (3)
DRAM tRD (4)
Specs
