Model of the motherboard: Biostar A785G3
Model of the memory: F3-12800CL9D-4GBNQ
Model of the CPU: AMD Athlon II X2 245 Regor 2.9GHz
What is the problem?
Multiple different BSODs and system deadlocks, usually after a few hours of operation, but occasionally it will go a day without a failure, and occasionally it crashes within minutes of startup. Mostly 0x24 and 0x1a BSODs, with a few others peppered in.
Using 9-9-9-24 timings at 1.5 V (had to set manually in BIOS--it tried to overclock by default).
So far this _seems_ to be isolated to one of the two sticks in the kit. Should I assume this is going to require an RMA, or should I be using different timings with this mobo?
