F2-5300CL4S-2GBPQ memory works correctly when installed alone. When it is installed with any other memory (F2-5300 CL5S - 2GBMQ and/or hynix Hym P512U64CP8-y5AB PC2-5300U-555 12 1GB 2Rx8), the motherboard sounds a memory error beeping and the computer will not start into bios. Memory settings can not be changed due to the bios locked by HP. Could this problem be due to the different CAS Latency?
Thank you.
HP Pavillion a6220n
MB - Asus IPIBL-LA
Chipset - Intel G33 Express Chipset
Processor - Intel Core 2 Duo Processor E4500 2.20 GHz, 2MB L2 Cache, 800 MHz FSB
Other Memory - (1) G.Skill F2-5300 CL5S - 2GBMQ DDR2-667 PC2-5300 2GBx1
(2) hynix Hym P512U64CP8-y5AB PC2-5300U-555 12 1GB 2Rx8
Windows 7 Pro 64bit
Thank you.
HP Pavillion a6220n
MB - Asus IPIBL-LA
Windows 7 Pro 64bit
