I hope someone can help. I have read around several forums for days and tried a pretty tedious set of combinations of slots, sticks, voltages and timings and still have an unstable system. I suspect I need to get the right combination of BIOS settings to get things to work but am currently tearing my hair out.
System details:
4 x F2-8500CL5D-4GBPK ram whcih I am trying to use with my
Gigabyte GA-EP45-DS3R (with latest F11e beta bios)
Intel Core 2 Quad Q9550 2.83 GHz Processor
Windows 7 64 bit
The system, over 12 months old, has always been unstable with regular blue screens.
I have finally been able to investigate by running memtest86+ v4.0 and it instantly through up errors.
I have managed, with only two sticks of ram, to run it through memtest two or three times (for around 1/2 hour only) without it failing. I did this by increasing the Dram Voltage to 2.1v as mentioned on this forum.
It is set to 5-5-5-15, DRAM 2.1V
After this success I tried to get all four sticks working but without any luck. I went back to two sticks and now that will not pass memtest ether
I don't believe there is anything wrong with the ram or the motherboard but I just can't get them playing together nicely.
I have read about increasing the MCH voltage but that didn't help and someone else suggested increading the FSB voltage but I couldn't find that option and am not sure what difference that would make.
I don't want to overclock I just want stability. It is driving me crazy and I am close to ditching the whole setup and going down the Mac route.
Please can you tell mw what bios settings I should be using?
Any and all help gratefull received
Best regards
Andy
System details:
Windows 7 64 bit
Best regards
Andy
