System unstable.
  • System unstable.
    I have just built a new system and installed Windows 7 Pro 64 bit on it. The system is very unstable. It frequently freezes up on me.
    My BIOS has all of the RAM settings and timings set to Auto. The Voltage was set to 1.95. I tried setting it to 1.8 and it got worse. I changed it to 2.1 and it seems better. (Even though my RAM has 1.8-1.9V on the sticker.) I thought if I could decode the RAM timings and get the BIOS set correctly my system might become more stable. The problem is I am not sure how to match up the 4 settings (are they CL-tRCD-tRP-tRAS ???) with the settings in my BIOS. My BIOS has like 7 or 8 different settings.
    Model of the motherboard: DFI LANPARTY DX X38-T2R
    Model of the memory: F2-6400CL6D-4GBMQ : DDRII800, PC2-6400, CL6-6-6-18, 1.8-1.9V
    Model of the CPU: Core2 Duo E7500 Wolfdale 2.93 GHz 3MB L2
    More Info:
    DFI LANPARTY DK X38-T2R LGA 775 Intel X38
    Intel Core2 Duo E7500 Wolfdale 2.93GHz
    G.SKILL 4GB F2-6400CL6D-4GBMQ DDR2 800 CL6-6-6-18, 1.8-1.9V
    RAIDMAX HYBRID 2 RX-530SS 530W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready
    POWERCOLOR PCS Radeon HD 4670 1GB 128-bit DDR3 PCI-E 2.0 x16
    SAMSUNG Spinpoint F3 HD253GJ 250GB 7200 RPM SATA 3.0Gb/s
    ASUS DRW-24B1ST SATA 24X DVD Burner
    Rosewill RNX-G300EX 802.11b/g PCI Wireless
      Yes, CL-tRCD-tRP-tRAS 18
