Motherboard:Asus P5K
CPU:Core2 Quad Q6600 2.4
Memory: F2-6400CL5D-4GBPQ 2x2GB
Problem? Ok I already RMAed one set of these 2 sticks to new egg thinking they were defective. The new ones do the same thing. Everything runs normal except when I try and play World of Warcraft. It will load into the game and then the whole PC will freeze. I went into the BIOS and changed the timing,voltage,command rate, and mhz. Still the same problem. Asus hasn't pelpied to me at all for any info reguarding this matter, so I am trying here. Any suggestions or should I just send it back to newegg and by different ram? Also my previous ram still works fine but is only 2x1GB sticks of OCZ Reaper Edition PC2 6400. Only difference is the reaper is different timing and 2GBs less. Both are 800mhz.
