I purchased the G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory (Model F2-6400PHU2-2GBHZ) from Newegg in August 2007. These modules were absolutely perfect for over two years in my first custom gaming build.
November 2009, my Abit ip35 pro began to error during POST. This motherboard has a built-in LED display of any POST code errors, so I knew almost immediately it was a RAM related issue. I tried everything I could find to get them to POST but I think it was just their time to go.
Having no other sticks to test, I bought a different 2x1GB kit, model F2-6400CL5D-2GBNQ, as it was the most similar G.SKILL I could find available. These got me through POST immediately and have so far been working wonderfully as a replacement.
I want to add another 2x1GB kit to work with my 2GBNQ, and would like to know:
-Can I still RMA my 2GBHZ kit for new ones?
-Is it advisable to use all four of my DIMM slots for 4GB? (Instead of, for example, a 2GBx2 solution)
-will two different dual-channel kits (2GBHZ and 2GBNQ) work together as 4GB?
-will two of the same dual-channel kits work together?
-if they must be the same, are the two products similar enough that I can RMA my 2GBHZ kit in exchange for 2GBNQ?
I just really don't know very much when it comes to memory. If anyone has some advice on this subject, I would greatly appreciate it.
Thank you,
adam.
Thank you,
adam.
